Microcogeneration with Lombardini engine 3 cylinders
sakurasanta86
Message par sakurasanta86 »
Hello everyone and happy holidays!
I have just installed a generator of 12 kW output on a Lombardini engine LDW1503 3 cylinders 1500 rpm water cooled.
This engine is equipped with a 140-150 bar pressure cylinder pump injector.
I also recovered the cooling water from the exhaust manifold, the exhaust, the engine block and I also power a modular electric boiler needed for the house.
I heat 5300 L of water in about 8h (passage of 12 to 80 °).
Everything works perfectly on diesel and I now want to switch to the HVU.
I did a feed test directly cold (minimum 12 ° regardless of the outdoor car temperature my group is in a frost-free place): the engine starts and stops right away.
My filters are not facet car caps that I added sending oil in the return circuit.
I thought I could feed cold 100% oil car I still believe in Santa Claus :-P
What method to adopt to find the simplest way to run 100% oil?
The fuel supply scheme is here:
http://www.cjoint.com/14dc/DLAaZd8ftv5.htm
Thank you in advance for your suggestions.
